Hey all,
This is my 3rd year with my 84 K10. Its a clean original 113k mile truck. The first couple years I spent a lot of time tinkering with the distributor & carb tuning and in hindsight ended up wasting a lot of time on the OEM distributor which ended up having a whacked timing curve. About a month ago I followed the advice of some old school mechanics and junked the ESC distributor in favor of a generic summit non-ESC HEI. Long story short, after 3-4 hours of dialing it in I ended up with a truck that runs WAY WAY better than it ever did with its original distributor. I was one happy camper because it went from a total dog to making a surprising amount of power for a 305, and it has near perfect driving manners. But per tradition in my garage I can't ever seem to cross one problem off the list without adding another, and now its burning oil like crazy on a cold start. I wouldn't say they are giant clouds, but definitely visible. If I let it idle in the driveway it will gradually fog out the neighborhood, and it stinks bad... hell I have a splitting headache from trying to diagnose it for 5 minutes. Revving it will make a healthy puff of smoke as it settles back down. However, if i take the truck around the block for 20 minutes until its fully heatsoaked, the problem seems to dwindle to absolutely nothing. Even revving it hard. But I can't deal with 20 minutes of horrendous fumes every time she comes out of the garage. Most of the smoke is coming from the drivers bank of cylinders.
I had 3 possible theories about this. When I was tuning the dist I changed some vacuum lines around for better performance so I thought maybe one of them might be sucking oil back through the PCV. I verified they're all dry, so I think that's out. The second is that I may have missed an O-ring or something of the sort with the distributor install. From the documentation i have that doesn't appear to be the case but still possible maybe? And third, I'm thinking its a likely possibility that the extra 40-50hp I gained from this new distributor (seriously) might have found a weak spot in this 34 year old engine... valve guides or piston rings I'm not sure. Prior to this the truck would make a mild puff of smoke on startup and clear within seconds. Wasn't really enough to bother me but this is a different animal.
Anything else to consider before I
? Only other thing I have in the back of my mind is a compression test but it doesn't seem to be lacking power. Cheers!
