Update-I didn't get it running. I wasn't really motivated to work on this truck, so I worked on it little by little fearing for the worst.
I put the pump in the tank, hooked up the fuel lines, replace the fuel filter, and put a few gallons in the tank. I hooked my fuel pressure gauge and the truck made 40psi which is spec for this truck, but the truck didn't want to run. The few times that it would "hit" it acted like it was running on one cylinder. ****
Looked at the plug wires and those look the factory wires-from 92. **** now I have to replace those just to make sure I don't also have a problem with the ignition system. Replaced the plugs also. I seem like like only #2 was little moist from the fuel. ******* yooouuuu.
I probably could have got by just doing an ohm check on the wires, I didn't want to take the chance. Hmm, my online guild and the actual firing order have the 2,3 wires crossed. What the **** is it? Well let wire like the on-line guide because I'm not the only person to work on this turd. Still will not start. Now it is starting rain, and have other business to do. (this was last month.)
Well, I getting tired of working on this turd and I have it all apart. Hell, the fuel tank is still siting on the ground. I didn't want to do the fuel pressure test while the tank fully installed because I didn't what to drop the tank again. It was just that the lines and wires were long enough to reach the tank on the ground. Installing the tank wasn't big deal but the fuel filler hose was the biggest pain the to do. Ended up having take the bed off just so I could tighten one stupid hose clamp. Removing the bed would not have been bad if it didn't have a camper shell, bed liner, and the bed was full of junk. Plus the bolts to hold the bed goes though the top of the bed and the bolts have torx 55 head which I did not have socket to fit.
It seems like every Ford I work on are difficult to work on and this Ranger was no exception.
**** it. let see this bitch would run on Ether. Switch the firing back to what it was, spayed some starting fluid down the intake and it ran till it ran out of Ether. Well, it has spark and compression. It has fuel pressure at the fuel rail which the gauge port is also a pain to get to, so the fuel injectors are plugged.
This is one of my biggest fears. That means the sugar got that far in the fuel system so the motor probably burned some sugar. 4x4high wasn't the only to have told me told me the sugar glazes the cylinder walls. If I replace the injectors, the motor may still be junk because it going to burn oil and may not pass smog. This has spiraled out of control and cost, and don't think this ranger is worth it. I button up a few things and gave her truck back telling her what I've found and didn't think it was worth going much farther.
I decided to eat the cost of the parts I've put in this turd because I didn't get it running even though she offered to pay.
