mtnman210
I've had this problem for a couple months now. The water in the radiator goes down randomly. Sometimes I can drive on the freeway and I'm fine, I'll only loose a little. Then I'll drive around the block and the radiator is empty. But no matter what I've driven it I have to put water in. I've checked all the obvious:
Looked for leaks...no drips running or not running
No wet floor--can't be coming out the heater
Oil is fine not milky---not going through the oil
Exhaust--the only time there's any water in it is on start up but it's just the normal condensation
The most recent thing I've found is that it goes down If I have the vent open...not air just vent. But again, no wet floor.
I'm looking for any ideas I may be overlooking or forgetting.
could not figure out what it was , but sure is a pain in the but.
