With good shocks and good spring your ride will be much more enjoyable.
I look at a rough country shock as a very sub par shock.
Hell in my eyes a bilstein 5100 should be a standard style shock...
I may be biased because of the suspension setup that i have, but it works fantastic for what it is.
IMO if you want the best of leaf sprung suspension, you go ORD alcan springs and a quality shock. Expensive yes. You are talking about $2k in springs and bushing and shackles, plus another $400+ in shocks.
To do all 4 corners.
As of now I have custom springs up front, about $900 with all ORD shackles and bushings, and I have stock 52s rear with a shackle flip. It works fantastic for driving. In the dunes I do not love my rear suspension but I think another set of custom springs will change that.
I found a set of 4 svt raptor shocks for $700 (less than what you would pay for 4 fox 2.0 resis) and the suspesion works much better than I fell 95% of lifted leaf sprung rigs do. It works much better than it did stock as far as road driving as well. Offroad driving is massivly improved from stock.
In this video you can see the front suspension working very well, (try not to notice the amount the tcase moves or the vibration sounds as my driver side engine mount was blown at this point and the engine was bouncing on the frame....)
You can see that the suspension sucks to the ground the entire time (except when airborn)
I am not trying to convince everyone to run this setup, just showing that soft springs and good shocks will make a massive difference. I hope to have a much better video this summer to show what can be done with an all leaf sprung rig.
