Super lift spring question
George_Pimpdaddy
Edmonton Alberta Canada
So working on lifting the blazer with a buddy and about to bolt up the front springs but not to sure what way they go in. Like what way is front and rear? The sticker is still on them if that helps. anyone know?
Mine have stickers that say front on them. My part number stickers are by the shackle.
They look the same though to me. No military wrap. The leafs are the same as far as where the clamps are and stuff. So it might not matter
Most superlift springs have built in shims, is there shims on those. The shims point the pinion if that helps any, they were built in my 8 inchers.
Larger bushing up front, smaller at the rear. Gives you a little more clearance to the frame at the shackle end. Other than that they are symmetrical...
Rene
Mine did also. I know the rears do. I got the front used so I'm not sure if they were on them new or not.
