superlift spring bushings
k20
3/4 ton status
Mineral Springs, NC
Got a set of 6" superlift springs for the front of the cucv, coulda sworn I had a set of bushings laying around but cant find em. Anyone got a set layin around they dont need? As always cheaper the better.
I'm not sure on front springs, But the Bushings that DIY4X sells on there website fit Superlift rear springs
Im not familiar with thoose springs, i got several bushings here brand new from energy suspension, do you need the complete set??? let me know also are they the same widht as skyjackers?? cause ui have some with the fat lip and others with the thin lip
I dont know much about em either, friend of mine got em and didnt want em so he gave em to me. I'll do some research and see what I can find.
are they the same size as OE spring bushings? I ordered too many sets at work for a customer. They're for the "rear" Not sure of the specs. Energy suspension.
I have a set of yellow bushings I dont need, they are probably superlift being that color.
Get me some dimensions like inner dia of spring eye etc, not sure if inner size is correct for your bolts though
only problem is they dont have the inner metal sleeves in the bag and I cant find them
Alrighty guys, got the measurements (finally) the springs have a 1 1/8" bore front & rear. Also will need the thick (1/2") shoulder on them. If you have the stock frame shackle bushings laying there doing nothin I would take them too, hint hint. I cant even find my damn sleeves so 88jimmy's wont help me, unless I stumble on em.
What pisses me off is I had quadruple of all these things, then my buddy did his suspension borrowed my spares and then they dissappeared. Then I got more spares from other springs and those have gone AWOL......I cant win.
