superlift springs driving me crazy
greythorn3
Anchorage alaska
heres my problem i got superlift springs, and every week or so i have to hit them with a hammer to alight the springs in the spring pack this is happening on my front and rear springs.. the fronts a superlifts. and the rears are another brand im not sure of.. they shift for some reason.. is there a solution anyones thought of yet?
Ray
sounds like the center pins are going bad. and also your ubolts are not tight . crank them down . at work i use my ir thundergun till thay basicly stop. but i dont just sit there till thay do ether. never had your problem.
I've had that problem with my SUPERLIFT springs since they were new. take a piece of thin small strap steel bend it around one end of the spring pack so that the ends just touch . then tack-weld it. to keep it from moving around put some tape on it. you don't want to weld to the springs,, thats a no no.
yup
well thats what i was thinking i would have to do.. damn it! its just so dang frustrating one of my rear leaf springs shifted in the pack and busted my caliper braided brake line.... do you use the tape to keep them from sliding front to back?
Ray
Yea Your Basically Doing What The Hired Help At Superlift Should Have Done In The Frist Place. Some Times It's Not Too Hard To Out-think These Folks.:d
