CAT 245ME
Registered Member
I'm curious who here is running Superlift front springs. I put new 4" HD springs in the front of my 85 K20 a while back and I notice the front end doesn't sit level. On my LH side I have 9 5/8" of clearance from the top of the tire to the top of the fender lip, but on my RH side there is only 9" of clearance. Now the back of the truck sits level, both sides are 9 3/8" of clearance (stock springs & 3" blocks. This truck was a frame up rebuild, everything is ether new or rebuilt.
When sitting in the cab you can definitely notice the difference on flat ground, it drives me nuts. This is my second Superlift springs, my first was the same thing except I had an 85 K10 with 2.5" lift and the difference between the LH & RH was 3/4".
I'd like to know what experience others have had with the Superlift springs and also how does the competition compare with being level in the front end.
