I own an 82 Blazer that I converted from the 6.2 diesel to TBI from an 87 Blazer. My problem is that I have a very rough surging idle when I first start it up (Almost like I have a "big" cam installed). The surge gets siginificanlty better as the engine warms up but you can still make out a slght surge at full temp. I also smell a slight hint of fuel in the exhaust. Aside from these issues, the Blazer drives well and never has been a problem at start up.
I have checked for vacuum leaks and have not been able to locate any leaks. I am leaning at two things at the moment: TPS or Bad Injectors.
I have performed the voltage reading test on the TPS at the closed, mid, and fully open positions on the Throttle body and everything has checked out. Can this unit be partially bad? Would you catch this on the voltage test?
The injector spray pattern is not a fully atomized spray on the driver side injector, but it is not significantly bad either.
I would appreciate it if somebody could guide me in the right direction.
