badmix
I just ordered some HD shackles and greasable bushings from ORD, woohoo. Anyways, this is one of those "never did this before" projects. What would be the easiest and safest way to replace my bushings and shackles.
1) Lift truck off ground with suspension unloaded (jack the body and get wheel off ground) Springs wouldnt have any pressure on them at this point
2) Lift truck off ground under axles, this would get truck in the air but still compressing springs
3) Leave truck on ground (this would still have pressure on springs and still be compressed)
The springs on there now are 2" rough country springs front and rear.
Thanks in advance
(just want to do this safely and easily as possible.)
Thanks in advance
