suspension bushings
tim_87
louisiana
my other posting for smoother ride brought many good suggestions. in looking for a smoother ride i have changed shocks next will be the tires because they are about gone. i am looking for more information on the suspension bushings and the swaybar bushings. the swaybar bushings are badly worn and cracked. and how difficult are they to change out. thanks for all the suggestions.
musicman
Member's experience is welcome on this one, how are the bushings to remove from the bar?
The fronts are a no brainer, they're split and just come right off. The ones in the end may need to be drilled or "smoked" out. When you install the new ones, use some grease, and clean the holes out with a file to make sure they can slide in without hanging up.
Making the world better, one truck at a time.
SW-ORD
I've been using a drill todo this for a bunch of years. The bushing comes right out this way. The Urethane bushing then slide right in place.
Mike
