Houston_t
Registered Member
So here’s the deal I just recently purchased a 87 Jimmy from Oregon, I’m in Michigan so sometimes we have to go to those extremes to find a rust free car and this one is most certainly 100% rust free, it’s never had any rust repairs and still has the original paint.
Anyway it’s my new summertime daily driver and I’m slowly getting her together thanks to this site and it’s members. What I have done so far suspension wise is take off the 6 Rancho shocks and install 4 Monroe shocks, this alone made all the difference in the world to its ride quality,
couple days later I swapped out the 15 year old dry rotted tires for some new 31x10.5x15 BFG KO2’s, this change showed me I went too cheap on the shocks because now with the new meat the ride is a little to bouncy
I plan on getting better shocks in the upcoming months probably Bilstein yellows. Here’s my question how do you guys feel about the ORD greasable shackles ?
My truck has stock springs to my knowledge and I don’t want to change the ride height much but I just want to add components that will help improve the ride quality as this is a true daily driver till salt hits the pavement.
The reason I am even looking at the shackles is because when I take off from a stop there’s a solid click that I can feel and hear, looking at the spring bushings I can see they are dry rotted but this may or may not even be the cause of the noise but since they are dry and cracked figured why not start there.
I have not had a chance to have anyone rock the wheel while I checked other suspension components yet but everything is getting changed just for piece of mind so if you have any component recommendations let me know, other than springs these seem to be in good shape. Also I looked at the body bushings and they are in great shape must have been changed before.
Thanks for reading this and let me know your thoughts on the ORD shackles.
