I would assume if it’s an oil, that it doesn’t actually dissolve rust. It may coat it and keep it from getting worse, but that’s it. There are rust converters that supposedly convert rust to a more stable compound, but they don’t dissolve it. Only thing that actually dissolves it is acid or specialty chemical, but those need to be covered over with something to protect the metal after it’s cleaned.
I’m using cosmoline for my build. I would recommend you do the same. Rp342 in a can works great or get a 5 gallon jug for all your vehicles. https://www.cosmolinedirect.com/mil...MIs9vr0_fO5QIVrP7jBx2W-ANvEAsYAyABEgI3cvD_BwE
Try eBay.It's really hit and miss with American products over here. I basically need a rust converter, and a wire wheel. Then wipe it clean and spray a primer. Then use a spray type paint or a paint brush to cover it.
Try evaporust, it actually removes rust and gives you clean metal no need to wire wheel after.I just checked. Neither product available here.
I know you can get it on Amazon but not sure if you can get it to Sweden
