I take it you have seen my build if you are mentioning cal-traks. I'm the only one running a set so far. I like how cal-traks work and the cal-traks don't bind the suspension like a traction bar would.OK
how to have more travel with minimal lift ?
also what traction aids are effective in sand ? i.e. traction bars or cal-tracks ?
As for travel, the limiting factor is the shocks mounted in the factory location. There is little travel with the shocks mounted there. I’m going to build some shock hoop later. As for travel with minimal lift, I don't know as of yet, since I'm still experimenting with the suspension. I will say this, I'm going to need taller bump stops or hydraulic bump stops for the front because I killed a set of 52" springs.
No wheel hop at all, but I haven't tried it in reverse which could be a problem. Cal-tracs are made to work going forward.
Cal-tracs are designed to prevent wheel hop while going to instant center. Hell, drag car use Cal-tracs with mono-leaf springs.
The 52" springs are just right for the sand IMO. The only problem I'm having with the 52" springs is a severe sag on the passenger side. The spring got damaged when I caught air. Taller bumpstops should solve the problem by preventing the spring going into a severe negative arc.
The U-bolt flip was supplied by Cal-trac. The spring plate has a bracket welded on for the link mount. Cal-trac did this so their kit be a fully bolt on kit.
