gerber boy
Registered Member
okay i have a chance at a 91ish chev 1ton or 11/4ton. it has a 6.5 turbo with mechanical injection, and what i orignally thought would be a 4-speed but it has LO 2 OD
1 3 R
would this be the NV4500?? and what transfer case is behind it?
it's a dually with a blown apart pinion on the 14bff, probably a clutch, hasn't ran in a year. still turns over but not fast enough to start. so not sure how well it runs, 320,000 KM on it. i can pick up the whole truck for around $600.
is it possible to put this in my 83 K5?
how much trouble would i run into? what would be involved?
also what transfer case can i swap onto this tranny? I have a 203 on a th350, a 208 on a th350, a 205 on a sm465, and 3 other 203 boat anchors.one with a part time kit.
What would you guys do?
1 3 R
. If you don't have A/C in your truck, the hardest part is making the downpipe off the turbo work. With A/C, considerable creativity is required to make the turbo clear the HVAC box. Everyone's solution is different, I'd be happy to send pictures of mine if/when you need them. Good luck, and happy wrenching
