My 700r4 swap is done...but I have a t case that is burping fluid out of the vent tube.
Not over full
Vent tube is run to the firewall.
Seems to be at highway speeds
I filled the t case with a blue fluid to make sure it was not bleeding from the transmission
I have read where these t cases had a problem with doing this and gm had to correct it.
I have also heard of mounting a catch bottle that would allow it to bleed back to the t case.
Any advice would be greatly appreciated. This has been a long process for someone that has never done it before. I would like to cry right now but for some reason I can’t.
I have access to a np208 but I am not sure it won’t do the same thing.
Not over full
