Swap meet thread BB08
wasted wages
1 ton status
Dallas Texas
Just a thought,,we could use this thread to post up any parts that anyone going to BB08 would be willing to bring with them that they have for sale,
or to ask if someone has a need for parts that a seller might have and could bring with them.
Such as,,,
I have a need for 2 Chevy D60 hubs / spindles / brake caliper brackets to convert my D60 Dodge to Chevy.
Also if anyone needs something hauled between Houston and Moab or back
let me know...( parts only, I don't have room on the trailer for a second vehicle )
I have all kinds of poop. Tires and Wheels ck it out on craigs list for the Tires and wheels. Also some steering parts a sway bar as well as ORD disconnects, Let me know what you need I'll try and get it.
Dood I need a couch and love seat brought from Houston to Moab, yes I am serious. I sent you a PM but I got my answer but I will pay you, it is big though.
I've got a set of milled/ drilled/ tapped flat tops. Only stipulation, I have them on CL right now. BUT, the guy I got them from had them tapped with COARSE thread, and I removed them because I broke 2 studs. 1 stud came out, but I had to drill the other one, and the threads at the top of the 2 holes are boogered a bit, I wouldn't worry about running them since the threads are deep, but just want to be upfront.
anyway, how about $150 delivered to BB.
Because of my move to Fl. next month, I will be bringing just about every spare part
I have with me. If I can sell some of it, that would be great. Some stuff I will give away.
Here is some of the things I will bring:
ORD disconnects, sway bar & bushings
Used flywheel & pressure plate
10B rear 3:73 with new drums & brakes (must get rid of)
Front tie rods
Stock U bolts & plates
Rancho 4" rear springs
10B rear axle (must get rid of)
spare drive shaft
Black Hard top (this will be dropped in Junction on the way unless someone says something before I leave).
D60 diff cover (stock)
4wd PS gear box & pump
Much more, I will add to this list this weekend as I dig stuff out so check back.
If you break something at the bash, call me, I might have it for you cheap.
couple parts
anyone interested in a freshly rebalanced and trued rear driveshaft, stock length, been in the garage for a while, need to get it outta the way, also have a stock spare tire carrier 406-799-2021
Any 37x12.50R15? I'll take anything, but i'd like a Goodyear Wrangler MT/R
Half tempted to sell my old single plane Holley Street Dominator intake . Good builder Quadrajet . Accell Supercoil for large cap HEI . And early large cap HEI TPI distributor . Just to get some gas money back .
I ain't gonna really use any of it . Going matched intake to the aluminum heads I buy , mallory , MSD , and Demon on the Chevelle . And don't plan TPI on anything .
Anyone got a spare in the 38.5" range for a 16.5" wheel?
If you guys don't have a spare, do what I do and at least pick up a tube so you can fix a blow out for cheap.
EVERYONE should just bring the parts and we'll set something up in the parking lot across from the park. Maybe on my trailer??? :dunno:
I have h1's so as long as I don't completely shred my tires I can make it out. I might have a tube in my garage somewhere though
