swap to 89-91 grille
3car
Hernando, Florida
does the swap to the 89-91 grille require a different radiator support???thanks for the replys...
eatin'fords and shittin'dodges down in the sunshine state.
current support is an 85'thanks
Yes.. it requires a new radiator support to accept the 4 headlight system.. I have a 83 and a 89 Blazer.. and they are both different near the light mounting area.
They are priced pretty good in LMC catalog..
Hope this helps.
I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
Yes, You will need the 89-91 radiator support for four headlight system. I did a technical writeup with part numbers in the Technical section. You should find it helpful. Email me if you ever have questions [email protected]
Mudzer 1978/91 K5
<font color=blue><a target="_blank" href=http://www.mudzer.rockcrawler.com>www.mudzer.rockcrawler.com</a></font color=blue>
Look here for more info.
<a target="_blank" href=http://www.coloradok5.com/grilleswap.shtml>http://www.coloradok5.com/grilleswap.shtml</a>
Russ
85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
