chevyguy82
Registered Member
i started the rear swap on my blazer tonight. 30 minutes to get the 10 bolt out. started bolting the 14 bolt ff in and found out my u-bolts will not work. they are too small. can't find any around here at oreillys or advanced. also need plates for top. where can i get them? also i need a ujoint for the rear drive shaft. i know there are some part numbers on here but does anyone know what i would need to get one from advanced auto parts? i usually buy the brute force ujoints. i tried to attach my 8 inch extended stainless braided line and found out the block is different and will not work unless i use the one from my 10 bolt. tried to remove the brake lines from the block and also from the drums trying to just swap lines from my 10 bolt and couldn't get lines loose. actually stripped the brake lines. they are 3/8. any advice on how to get them off the block or out of the drums? any help is appreciated. need to get it done in the morning and out of the middle of the driveway. i also removed my shims from my 6" bds spring packs. always had problems with breaking u joints even with transfer case lowered with kit. anyone know what shim to run. i've got an angle finder but if i knew something close to run it would be easier to just put them on now before the axle is bolted up. thanks guys.
