Swapping a cs144 for my cs130 with a few pics
nutt7
Ahwatukee, AZ -> JBLM, WA
EDIT: read all the way through so you don't miss some of my corrections/adjustments on wiring.
There is a lot of info out there about swapping a cs144 in your chevy. There is also a lot of alternator set-ups, so you have to find the right parts to match your set-up. Here is how mine worked. (I couldn't find anything definitive here about putting a cs144 in a serpentine belted, driver side alternator'ed stock rig, but maybe I missed it). I found this info via a lot of googling, and I found a guy that did this in his 95 suburban, which has the same set-up as mine.
I have an 89 burb w/350 tbi. The 105a cs130 I have has feet that are 120 degrees apart. The 140a cs144 I needed can be found on a lot of chevys from 1996-??. My donor vehicle was a 97 G2500 (Express) van with a 350. This one was a "remy new 91400" and it tested good at O'Reilly's. If you want a new one, tell the parts folks this vehicle or say, a 98 suburban or most other chevys of that era (I think 96 was the starting year for this specific alternator). Some folks need the 94 pontiac trans sport version. NOT for my set-up. These ones have the 180 degree feet. The cs144 I mentioned also has 120 degree feet, but it doesn't match perfectly to my bracket due to the fact that it is a larger alternator, so the 120 degrees of arc is longer.
Luckily the bracket is aluminum, so I spent a few minutes elongating it with a drill until I could push a bolt through it (I snagged the bolt from the donor, but you will need a nut now that the threads are gone). Here is some progress:
The rear support bracket will not allow the fatter alternator to fit, so I hammered it flat and bolted on an L braket from some scrap I had. Later I added a ground here.
All mounted. The stock belt fit for me, but I think my belt was a tad long before. My tensioner does not go down as far as with the stock one, which makes sense since the pulley is a little further away (pulley sizes are the same). The factory one wire exciter plug matches as well, but there was 12 volts running to it. I read the the cs144 needs a resistance (typically a dummy light) or you can damage something. Since my truck doesn't have a light, I had to cut the plug wire and solder in a home made resistor pack that rated at 55ohms and 1.5 watts. I read that the minimum is 35ohms and 5 watts (some say 1/2 watt works), or up to 350 or 500ohms and 1/2 watt. Time will tell if my set up holds, it might be light on the wattage side. I am pretty sure you can buy the harness plug with a resistor built in from napa or somewhere.
While at the boneyard, I also sourced some good quality 2, 4, and 8 gauge wires with ring terminals. I swapped a 4awg charge wire for the stock 8awg. I then routed the old one to my ford starter relay so I could take a ring off of my battery post. I added a 2awg ground from the engine to the frame. I also added a 4awg from the alt bracket to the core support and I want to beef up the ground to the firewall later on. I made sure to shine em up and protect them with dielectric grease.
I decided to do this since I did the headlight mod, added a fuse box for future items, and added windstar fans. With all things running, I was about 11.5-12volts at the battery. Now I am at 13.8 volts at full load (I still have some voltage loss in the cab, but that's another unrelated story). Turning on my windstar fans hardly makes it flinch now. My windows even go up faster and they will improve even more when I find the source of the ignition switch voltage drop.
I forgot to mention that this mod cost under $50. It could be more or less depending on your luck at the junkyard and what you have laying around your garage/shop/work area.
I put an older GM 10SI altenator on a friends John Deere farm tractor when he decided to convert it to 12v...and I used a mopar ballast resistor in line with the feild exciter wire (#2 on the plug) ..it worked and charged ok,but we noticed the coils on the back of the resistor glowed orange when it was revved up to full throttle..
It put out 14V at 3600 rpm or so,which I felt wasn't too high,so we decided to just use it as is and see what happened..it didn't melt the resistor coil and the battery stayed charged ok,I did end up wiring the original amp meter back up though,so we could see just how many amps it was putting out,it stayed around 10 amps most of the time,15-20 right after you started it up--once the battery recovered what it lost from cranking,it went right back to 10 amps..
First time we turned the headlamps on the both went off like giant flashbulbs...forgot they were still 6 volts...oops!..:doah:..
I occasionally go through my old posts in case things changed...this time it has! I overlooked something on this swap and I want to mention it in case someone follows my write-up.
My factory "one wire" plug was NOT the same wire that the new alternator's "one wire" plug used. Luckily I clipped the pigtail from the donor vehicle. I used it and ran that 12v wire to my main distribution area. This resulted in a little better performance (due to proper set-up) and probably added to the longevity of the alternator.
BTW, almost a year later and it's doing great still. I plan to find a new solution to the rear mount too. The hammered bracket is solid, but it makes valve cover removal a pain.
I found a 108 amp GM altenator from a later model Olds or Buick that was free for the taking when a friend scrapped a car--its a practically new rebuilt one....looks the same size case as my 10SI has,so it will probably bolt right on,the only difference I can see is the 2 "tabs" on the regulator where the 2 wire plug goes on --it looks almost the same as my original plug--but the two prongs are going "up and down " ( I I ) ,instead of side to side like my original ( -- -- )...I'd have to swap the serpentine pulley for a V belt too..
Never saw an altenator with a plug like that--usually its the typical 2 wire plug,or the new style CS ones with 3 or 4 wires that look like computer sensor plugs...:confused:
I think I could just use solderless connectors on each regulator tab to hook it to my harness,the altenator has the "1" and "2" cast into the housing like my original does,so evidently the internal wiring is the same--just that the plug wont plug right in...:dunno:
I remember having a customer come into the auto parts store I work at with an alternator that had a plug like you describe. He had just got it at the local swap meet, it was an after market chrome one. I don't remember what we found think he just bought some of the female blade terminals that have the cover around them and wired it up.
The plug itself does have 4 terminals, but only one is being used. the one being used by my factory alt was just different than the one the donor alt uses. So it's the same plug, but the "one wire" comes from a different terminal.
I just did this swap on my 89 Blazer. What pin should the wire go to? Mine currently goes to L and I am unsure if that is the correct one.
Also, I've read in a few places that a resistor is needed and some other places that it is not needed. Did you install a resistor on your wire?
Thanks for posting this. It made me realize something else. I'll post back with some details. Essentially, my factory plug had 12v going to F. That's it. I cut it off. The donor harness had one wire going to L. Currently my L has a resistor to simulate a dummy light. If no resistor to L, it can fry something in the alt.
I remember now that I hacked a 3 pin plug out of a Buick or something to use the sense or S pin. It's purpose is to adjust alt output when the S sees a drop in voltage. S goes to a distribution point like the two post block on the firewall near the booster. It is not necessary, but makes the alternator more efficient.
In short, you AT LEAST need L hooked up with a resistor to allow the alternator to function. Now I will go find the literature I pulled all this from...
EDIT: another thing: if you have a factory voltmeter gauge, your wire will run to F. If it's a light, your factory alternator uses L already I think...and you should be all good to go with no resistor...not a 100% on this...neurons are starting to fire again [emoji16]
Mine goes to L and I have the guage, thanks for the tip with S though! Definitely let me know what you find with the wiring.
You must have an idiot light too. What color is the wire to the L? If it's pink/black make sure it doesn't go to F! I did this the first time.
Pink/Black. I may be wrong, but I've never seen the idiot light come on and I drove it about a block with a known bad alternator and no light came on.
It probably goes to F then.
Here is a pic of my factory one on top (F) and donor harness on bottom (L).
There are lots of inconsistencies online about the wiring of these alternators regulators and their castings (cs130 and cs144). The F terminal is sometimes labeled I for ignition (at least on the cs130). If it's I, 12v switched here is all you need (like how mine was wired factory - and I suspect yours too). No L needed (but ok to use if desired). If F? Who knows how the regulator is wired...maybe it's the same as I, maybe not...but if it indeed is F, then L needs to be wired too.
Confused yet? I was. Let all my research make it easier for you and future readers: Simply put, L and S are the same on all of them. You can get by with just wiring L for all cs130/144s. S is just for optimizing the alternators capabilities. So use L and don't bother with F/I since L gets the job done every time. This is why I am insisting to make sure your factory plug indeed goes to L because I don't think it does.
In terms of L, use a resistor anywhere between these ratings:
35ohms, 5 watt up to 500ohms, 1/2 watt. If you go closer to the 35 ohm, be sure it's heavy duty enough. 5 watts is a high rating so you might have better luck in the 300-500 ohm range in terms of cost and availability. You only need the resistor if there is no idiot light (for future readers).
If you find a harness with S, don't put it to the alt post or the battery lug. Your alternator already senses from there. Put it down the line where measurable voltage drops occur, like where I said in the other post.
If anyone cares:
S - sense wire. Senses voltage drop to adjust output
F/I - field positive / ignition switch. F? Idk. I turns on the regulator
L - lamp or light. Turns on the regulator. Shows ground when closed to illuminate idiot light.
P - phase (used for counting stator pulses I think, for tachometer sense of some sort
If anyone cares:
So I'm a moron, my wire is on F, I misread the plug. Hope I haven't already fried the regulator...
Well I did the same exact thing and mine still works...whether there is an issue or not I don't know but it's holding up! I'm pretty sure F grounds when the alt is off too, so that can't be too good if you sit with the key on...but like I said, mine tested fine and continues to work!
Let me know how it turns out.
I got it wired this morning. And want to add some to your write up. Got these resistors at Radio Shack for like $1.60
Got this connector new at O'Reilly for like $9 you can get them much cheaper at a junk yard, but I didn't have time
Then some ring terminals
If you have the line on F then you will need to cut it and insert a resistor on pin L like nutt7 was talking about. Nothing goes to F. I also ran pin S to my terminal block.
After this mod I had 13.8 volts with A.C., electric fans and all other electronics at idle. Thanks nutt7!!
