NEK5
3/4 ton status
to an aftermarket one. What`s involved? Did a search, but didn`t find much. Changing of the VSS, or something else?
Also electronic....I believe that you can adapt the an autometer to it.
wait is the aftermarket mechanical or electric?
Well, they won`t actually mention the DRAC. I believe the DRAC has 3 out puts. 2000PPM, 4000PPM, and something like 128000PPM. So I guess whatever speedo accepts those outputs, would workThere are several I looked at that are designed for connection to GM setups. But they didn't mention the DRAC so I would contact them and see what they say.
Mind listing what you purchased? Prices, as well as where you got em?Yeah I just ordered all my guages and I think the total with a sending unit for the speedo and a guage cluster harness from painless was about 700 bucks.. I cant wait to get them and install them..
The speedometer is designed to operate with an electrical speed sender. The speed sender signal range must be between 500 and 400,000
pulses/mile (310 and 248,500 pulses/km). Any speed sender or electronic module that meets the following two conditions can be used:
1. Pulse rate generated is proportional to vehicle speed.
2. Output voltage within the ranges listed below:
• 4 to 16V (Hall effect sender, 3-wire)
• 4 to 120V peak to peak into a 10K ohm load (Sine wave generator, 2-wire)
• 5V Square wave (TTL)
Recommended – Auto Meter Hall effect sender, 3-wire 16 pulses/revolution.
5291 Standard 7/8 – 18 thread
5292 Ford, plug in
Once the speedometer is mounted and wired into the vehicle (see following page), the speedometer should be tested to verify that the electrical
connections are working properly. First, watch the speedometer’s pointer as the power is applied. The pointer should first move to a midrange
position, then down to the zero box on the dial. This action verifies that power is properly connected to the speedometer. The vehicle should be
driven some distance to verify the Vehicle Speed Sender (VSS) is connected properly and that the pointer moves. If the pointer does not move
out of the zero box, verify that the VSS is connected properly.
Well, I had intentions of running one of ryokens custom dashs..hopefully...If not, I`ll run a stocker. Thanks for the heads up!Hey I just got my gauges and found the tach and speedo to be way to small to fit in the stock bezel. I am ordering 5 in. gauges to replace the tach and speedo I originally ordered.. Just wanted to give you a heads up..
