Randy92782
1 ton status
Alright i wanna take the rear slider out of my '79 and put it in place of the solid window in my '80. I've never swapped these before so i was wonderin what it would take.
Damn and i thought i had an answerWondering this myself.
here ya go. # 3 post. and few other info there as well. plus it works for more than winshield glass. side glass as well in blazers and burbans.
http://coloradok5.com/forums/showthread.php?t=183818&highlight=glass
Yup it does. If it wasn't supposed to rain today i'd be out doing itthe last time i replaced a rear window i used a string to pop in inside window gasket.
take a length that will go around complete circumfrence of window
set bottom of gasket in have a helper push window in and hold other end of string as you pull one end string out toward you ( you will be on inside of cab) it will pull gasket inside the cab
Hope this makes some kind of sense
It shouldn't take long. Think me and my brother ought to get it. Thanks thoughIf you need some help let me know. Ive done a few myself.
Thought soYa i was in a blue car.
