I'm in need of sway bar bushings and hardware and was looking at your kit. Does the kit that comes with the bracket only for the older trucks or will it work on my 90 suburban?
We have a sway bar bushings kit for your 90. It does not come with the brackets, only the bushings for the frame mounts, and the sway bar ends. You will need to re-use your hardware, or if you order our disconnects it will come with new hardware for the axle end.
