I need to ditch my sway bar crossmember for some clearance issues. You can see here in the pic I have a winch plate welded in less than 10 inches from the crossmember. Obviously this rig isn't never going to see a sway bar (at least not a factory one) Anyone see a reason why not to remove it, to to replace it with one made of tube. Ideally would not be replacing it. My plan is to hopefully change the water pump out to a short style water pump and mount a 26x18 2 row AL radiator up front with a tube cradle for it, topped off with a spal low profile electric fan.
