Wanted Sway Bar Disconnect Kit
Shawn
Nuckin Futz!
Author
5280'
Before I buy this, anyone have one?
Let me know sir. Also looking for extended brake lines that fits k30. Looks like I should ditch the load leveling valve in the back too.
If you are ditching it because of a suspension lift, I just built a spacer that went between the frame bracket and the valve for my 1991 V3500, which extended the rubber brake line out enough that the stock length rubber brake line worked. I may have disconnect system too, but I was thinking of using the disconnect diff bracket to mount limiting straps to it. If you are ever going to go with cross-over steering, you may not want to waste your time with a disconnect system.
Good to know. So for a 4" lift you would use a 4" bracket? I was going to get rid of it for simplicity but may consider keeping it.
Yes, that should work. I just went to Home Depot, and bought some plastic spacers. Then I cut them down to the length I needed, and bought the proper length bolts as well from Home Depot.
that was a smart ass comment . yes i have them . just have to dig the bag out with the stuff .
Cool. Sounds like my garage with boxes and boxes of car STUFF. Can't ever find the damn thing when I'm looking for it. LOL No hurry.
