Sway Bar eye-lid bushing
Justin Fleming
Oxford MI
Has anyone come up with a good way to get these factory style eye-lid sway bar bushings installed? I know that there are two piece urethane ones out there but at this time that is not what I have. Just looking for ideas for installing stock units.
thanks
stock style rubber bonded to sleeve bushing like leaf spring bushings but just no outer sleeve is all .
there a tricky / pita / job .
Make sure sway bar is sanded smooth (the finer the better), soak bushings in hot water (makes pliable), then use a good dish soap as lube.
Lather, rinse, and repeat......:D
I haven't done those exact bushings, but this has worked for me doing similar stuff.
