When doing the ORD sway bar disconnect, do I need to remove a spacer that was installed on the frame for the 6" lift? The steering ( crossover) and sway bar hit during Right steering input near lock. Thanks again floks!
Yes
I have not yet seen a setup that uses both and WORKS.
You probably won't even notice it's gone.
