So -
Bought a used 4L80E with driver side drop NP241 this weekend out of 3/4 ton '94 Suburban.
I know next to nothing about the 4L80E to date - all my experience is with older GM trannies (T350 & SM465) and what I've learned from reading on the internet
Question is:
This 4L80E has the two VSS sensors - similar to a 2wd 4L80E setup (as I've learned on here) It also has a VSS in the 241? Right?
Can I use the two VSS in the tranny, and not run one in the 205?
If so, will this work correctly - even in 4low?
Question is:
You make valid points
