Sweet Suburban in Sac
dhcomp
1 ton status
Truckee, CA
Not affiliated, but sweet rig.
http://sacramento.craigslist.org/cto/2653493089.html
SUPERCHARGED 1991 Suburban (Sacramento)
Date: 2011-10-16, 7:12PM PDT
Reply to: [email protected] [Errors when replying to ads?]
1991 Superchaged Chevy Suburban 4X4, Lifted 4 inch lift on 1-ton suspension. engine oil, PS pump and transmission all have tripple coolers with aux fan. Tipple RS5000 shocks per wheel position front, with limiting straps. 2 RS5000 and 1 RS9000 per each rear wheel position. Hummer H2 17 inch wheels, with 35/12.5 BF Goodrich tires and new lug nuts all the way around. Dana front and rear axles with locker in rear, along with new Rancho torque bars and RS 5000 dampers. Suspension front and rear have been re-bushed with polyurethane bushings. Front and Rear diffs have axle truss armor plating, transfer case and fuel tank also have ¼ inch skid plates. New front brakes with new rotors and new rear brakes. New 4inch drop pitman arm and rebuilt steering box. Rebuilt TBI 454 HO with CARB legal Whipple supercharger, Nippendenzo 300 amp alternator, two new deep cycle batteries, fresh tune up, oil change and rebuilt oil cooler. Fresh 4L80E transmission with new stand alone fully adjustable transmission micro controller. Warn 10k winch with 16k nylon upgraded winch line. ALL new HID 9inch lights and two 4 inch HID lights front. Custom one of a kind rear bumper with built in storage, new spare tire, fire axe, shovel, three gas cans, high lift jack, new d-rings and CB antenna. 6890.00 firm, no tire kickers or dreamers please, tags good until July of 2012, CLEAN title in hand.
  • it's NOT ok to contact this poster with services or other commercial interests
PostingID: 2653493089
:eek1: Damm, 300 Amp Alt. Never even heard of one. Damm cool rig!!!! Like it a lot!!!!
I would buy that today if I was on the other side of the country:eek1:
Cool:
Axles, Engine, Chassis, Body, carriers, skidplates, lights
Over-the-top WTFockery:
300A alternator, triple coolers on everything (which oil cooler is the rebuilt one :haha:)
Retarded:
10k winch on a ~9klb truck, 12 shocks (unless the shock boots are neon, in which case it's AWESOME!), standalone trans controller on a truck that came stock with a perfectly good integrated one, 4" drop pitman instead of crossover
And those three jerry cans won't get you very far at all in that pig...
It might have been a 1/2 ton burb , if so that would mean it had a 700R4 trans and not a 4L80E so no built in trans controller, also
the 454 is swapped in I'm sure the Trans is too
You're prolly right...in which case it's even less appealing if all that's on a 1/2-ton chassis...
there is no differance in frames on 1/2 and 3/4 tons only the 1-ton trucks got the better frame
Not true
I have a 1/2 ton burb and a 3/4 ton burb. it's barely noticeable but it's thicker.
The 1 ton is taller and thicker.
Not true
I have two 91 burbs at the house and they are both the same ones 1/2 and the other is 3/4 :dunno:
Edit: I'll have to break out the calipers and magnet. LOL
Yeah, like the other guys said, the 3/4 is thicker and (more importantly) the C-channel is taller. I also don't knowhow he got the lift (aftermarket springs, blocks, or flip), but the spring differences between the two are significant.
I can tell you for a fact the frames are not taller. they be SLIGHTLY thicker but the are not taller all spring mounts and body mounts are the same
The springs are different yes but this one is lifted with aftermarket springs
For a 91 Burb the thickness difference is .015" I really doubt that makes any measurable difference in strength
