badmix
Any real benefits to switching to thicker weight, I'm in Florida. Truck is 84 K5 w 181k on odo and leaks oil.
Personally for those old engines with more than 150k miles I use 20w50, it cuts down on leaks and burning oil.Any real benefits to switching to thicker weight, I'm in Florida. Truck is 84 K5 w 181k on odo and leaks oil.
I just swapped my big block to rotella 15w40. The 10w30 had 55 psi cold but would drop off to the low 20's and even 18psi hot at idle. I was getting some valvetrain noise. The 15w40 holds at 28psi hot now idling and is still 55 to 60 cold. I think the engine should have been fine with 10w30, it was designed for it. I am happier with the pressures with the 15w40. This is a fresh engine. I had thoughts of a bad oil pump with the lower idle pressures on 10w30. Still not totally decided on the pump with 28psi idling hot with 15w40, I would have been happier seeing it in the 30's. Trying different oil is lots easier than swapping a pump.
