switching from a carb to fi on my 86
jd70ssclone
baltimore
hey guys how much work would it be to upgrade my carbed 305 with a 2barrel 670cfm kit from holley thanks
josh
I have been thinking about doing the same thing to my 85 350. I think all you would have to do is run a return line to the tank and hook up everything that comes with the kit. Then tune it and go. If I am wrong somebody let me know.
Have you thought of just getting the tbi system off of a newer GM truck? I have done many of these swaps on older gm trucks. It is pretty easy and you can find all the parts you need at local boneyards fairly cheap.
Look up Howell
excellent idea. Then have someone or yourselft burn a custom PROM for you engine. Howell sells a factory TBI "kit" with factory GM set up for little more than the Holley kit.
