Pookster
Which nano fiber filter are you referring to? Most oil filters are only rated to a nominal 20-25 microns, aka, "the full flow filters". I think the K&N have a rating of 10 microns. Most so called experts believe wear is most likely in the 3-5 micron range.
That aside, if you run a good bypass (gulfcost, amzoil, etc), then you can remove those particles as well as smaller.
Keep in mind however, no filter will remove fuel contamination.
Odd, my mercedes oil filter has a bypass filter in it.
