T-Case Flange Question
818scrambler
Registered Member
nova scotia
Ok, I've got a CUCV 6" lift on 37's with burnt 700r4 an cracked NP208 case. I'm putting in a th400 and used Atlas 4speed with 1410 yokes. Now I think I've got the rear figured out, I need to find a yoke from a NP205 and Build a new 1350 d-shaft or get a 1410 yoke for the 14bolt and build a 1410 d-shaft. I'm wondering about the front, Is their a junkyard 32spline flange with the same bolt pattern as the flange from the 208?
fyi 208 and 241 have 32 spline front outputs , :D:eek1::thumb:
and 1350 is good / strong but 1410 joint will handle more angle / flex before bind over 1350 .
older 205 tcase was early 10 spline then later was 30 spline on the front.
I just did a 32 spline front swap on a 205 with a flange yoke off a 208 . its a special seal # tho .
