T case gurus
Wes Harden
1 ton status
Staff member
Moderator
Solutions
Lake Havasu City AZ
Can the np208 front output flange be used on a np203 front output?
If so what mods if any are needed?
I had my exhaust fixed. I can put a front drive shaft back in. My t case is older ver with 10 spline output on front, I will have to change the output no matter what.
I may also have trans pan clearance issue. My thought was the deeper np208 flange would get me a better angle.
edit: boy did I screw up I meant np205 can the np208 front flange be used on a 205
