T-case Q?
blazen91
Hesperia, Ca 92345
Will a 208 bolt up in my 91 that currentlly has a 241? And which one is better? My 241 is spitten' fluid and no one can tell me why, and I know where a used 208 is I can get cheap. Thanks for any input.
blazen91
I am asumming you have a 700r4, in that case i believe it should, but one thing you might want to look at is how long the 241 is. your driveshafts may have to be lenghten or shortened depending
Doug Krebs
Strength is about the same on the 208 and 241, they r both aluminum. As far as gearing goes the 241 has a lower lo gear I think its 2.72:1 and lo in a 208 is 2.61:1. You have the 4L60 tranny right, it should have the same bolt up pattern that a 700r4 has(99% sure) which was mated to a 208 or (optional) 241 in some of the later 80's.
Hope this helps. You shouldn't have a problem bolting up a 208 to your tranny (98.9% sure), somebody correct me if I'm wrong.
<font color=blue>Professional <font color=red>JEEP EATER</font color=red>, it's a population control thing.</font color=blue>
Thanks guys. I may not have to change it now though. I was talking to a buddy about the oil the T-case was spittin' and he said his did the same thing, so he ran the breather up under the hood almost to the hood. Where does your t-case breather run to?
blazen91
