t-case swap
alwantsa4x4
Newbie
pevely, mo
Anyone know if there is a t-case w/ r-side drop that will swap in place of an NP231 for a solid axle swap? It is in a 1994 gmc w/ a 350/4L60E/NP231, planning a solid axle swap using 78 chevy dana 60.
Yes, if I am not mistaken the 4l60e still had a 27 spline output shaft, 4 bolt tailhousing pattern so a 208 or a 241 should be fine.
I have the 208 and adapter in that flavor if you can confirm what I stated.
yes is does have the four bolt pattern tail shaft housing and I beleive that it does have the 27 spline shaft, I had the tranny rebuilt in April.
208 should work. i just did this on the back of a 4l60 on my 93 s10 blazer. just had to use the 700r4 adapter
