t-case to bellhousing bracket, what does it look like?
Westside K5
Registered Member
Muskegon, MI
What the title says; I was informed by Dueling that I'm missing the bracket on the right side of the t-case going up to the bellhousing, but what does it look like? 1989 Blazer, 350, 700r4 & 241 t-case
So if you have a pic of the entire thing, please post the pic, please.
If you are local and have one, let me know, otherwise, I'll be running off to the junkyard, which is fun too!
thanks, Jeff
I thought I showed you mine? :dunno:
Not sure if 241s are different but the side of the case on yours looked a lot like mine
the two bolt holes behind/ on top of the output, from there a rod goes up to the corner bellhousing bolt.
Dueling, I should have.... but I didn't.
K85 - Yes, those are the bolts in question. If I can see what the rod look like, then I'll know what I need to look for in the junk yards or if someone tries to sell me something else that is not what I need.
I also figure if someones posts a pic, then everyone would know what it is if they search in the future.
I'll take a picture of mine when I get home. It's about 2.5 feet long if I remember correctly. Has 2 bolt holes for the t case and 1 90 degree bend where it meets the bell
There is a clear pic in the link in my previous post.... :whistle:
If I wasn't sick, I'd crawl underneath, but from crouched down next to it, I measured (ROUGHLY) 40", from near the mounting holes to the bellhousing. It is the 700r4, the longest tranny.
Maybe tomorrow after my daughter's surgery and I feel better, I'll crawl under.
Thanks guys for the help!!
Nvrenuf - Are you still selling the T-case supports?
