Drove the blazer some today, make sure things are good for BB.
Drives good in 2wd. Nothing weird, steering is good, shifts are good, etc etc.
Hubs unlocked and in 4H and it’s ok but there’s some clunking or rubbing noises mostly on decel.
Put in 4L and it’s a horror movie. It grinds and clunks with each up shift and again on decel. Put the trans in 1st and it’s better. The noise is lighter and on decel mostly. Still has a sporadic clunk.
This 241 has been flawless since install some years ago. Got the linkage modified for the clock and it’s been perfect, butter smoothish. Hasn’t seen rocks in a couple years and now she’s throwing a fit.
Could this be low fluid? Or something else? Because it’s clocked, I’m not going to be able to get fluid on the finger. The check bolt is way higher now and would be over filled if it came out of there. How much fluid should be in a 241?
