T-MAX and Mile Marker Winches!!!!!
81jimmyslt
So Lake Tahoe (Rubicon), CA
Now offering T-Max and Mile Marker winches all models available.
Get a quote or add one to your bumper order!
T-Max:
Integrated series
12,000 -- Fully integrated winch design include factory wireless remote, roller fairlead, galvanized aircraft cable, with replaceable clevis hook, 6.6 hp motor fir fast cube speed and us submergible. $995
10,000 -- Fully integrated winch design include factory wireless remote, roller fairlead, galvanized aircraft cable, with replaceable clevis hook, 6.6 hp motor fir fast cube speed and us submergible. $895
Standard Series
12,500 -- (5665kgs) rated line pull 6.6 hps 12v series-wound motor, 3 stage planetary gear train, Posi-loc, in-drum brake, power in and out galvanized aircraft cable with replaceable clevis hook, includes roller fairlead and remote. $690
9,000 -- (4080kgs) rated line pull 6.6 hps 12v series-wound motor, 3 stage planetary gear train, Posi-loc, in-drum brake, power in and out galvanized aircraft cable with replaceable clevis hook, includes roller fairlead and remote.
$495
Mile Marker Winches
SI 12,000 -- (5400kgs) rated single line pull, fully integrated 4.8hp 12v with low electric current, planetary gear train for fast line speed, power in and out, free spooling, galvanized aircraft cable, roller fairlead and remote. $695
SE 12,000 -- rated single line pull 12,000lbs (5400kgs), 4.8hp 12v or 24v motor, low electric current, planetary gear train, hardened drum, power in and out, free spooling, galvanized aircraft cable, roller fairlead and remote. $595
SE 9,500 -- (4300kgs) rated line pull, 4.6hp 12v or 24v, free spooling, planetary gear system for fast line pull, galvanized aircraft cable, automatic load holding brake, roller fairlead and remote. $495
SE 8,000 -- (3629kps) rated line pull, 4.4hp 12v or 24v, free spooling, planetary gear system for fast line pull, galvanized aircraft cable, automatic load holding brake, roller fairlead and remote. $395
If you need a quote or have any questions don't hesitate to call, PM or E-mail us!
Thanks,
Jesse Kruger
www.blazenoffroad.com
[email protected]
530-416-7902
Wow, good prices. I'll definitely take these into consideration when I put a winch in the back of my junk!
Say, do you know the difference between the 9/12.5 and 10/12 split...both of them look like they share the same motor, are certain components more heavy duty or is one geared lower or what?
Good eye, T-max uses the same motors in each different series of winches. Even their competition winches have the same motors as the standard series.
The biggest differences are in the winch control box, on the standard series the control box iis square and can be mounted in several spots. T-Max also has their outback series has a control box similar to the competition series.
The integrated series, the control box is built into the unit and it comes with a wirless remote, and is submergible.
The integrated series is pictured above. For spec on T-Max winches go here http://www.t-maxwinches.com/winches.htm#atvseries
Outback Series
Competition Series
How about a tmax for my trailer? Something smaller, just for loading roller "cars/trucks" with. Got any suggestions and prices?
T-Max outback series 12,500 ---- $845.00
Mile Marker 3,000 utility winch ---- $245.00
Clark if you would prefer a small T-max let me know but we have better prices on the small Mile Markers!
is the only difference from the outback and the standard the control box?
