k51977blazer
Where can I find the tabs where the bolts go into to hold the hard top down
Electrical supply stores should have square nuts,they are often used in that trade--also on Uni-Strut and shelving ..shouldn't be hard to get locally..
I have half a 5 gallon pail of 5/16" course thread square nuts left over from assembling my quonset garage--I build wooden end walls ,so I didn't need a lot of what came with it..
I seem to remember them more like a strap, longer than a square. My memory could be getting rusty but I will check tomorrow when I go work on it.Pretty sure you'll have to make them. I assume you are talking about the captured nuts under the bed rail?
IIRC they are just a square nut inside a spot welded metal cage.
Could always check LMC.
Yeah wasn’t to bad I used the bar stock and tapped the holes I only need to make 2 which wasn’t to bad thanks again for your helpHow was it? Not too bad?
