I've got a left over factory tach cluster here that I won't be using. It is a custom built unit that will require some re-pinning in any truck that it is installed into.
It is an orange ringed tach, and the speedometer reads in kilometers per hour instead of miles per hour. The cluster has been cut behind the speedometer head to be able to install a factory VSS for cruise control or fuel injection. It has a factory Volt gauge, factory machanical 0 - 60 PSI oil pressure gauge, and factory temperature gauge (without units, so it is universial). The fuel gauge is located in the bottom left.
Idiot lights include the 4x4 light, choke light and park brake. The 4x4 / choke lights are located below the speedometer, the park brake light takes up the entire space under the tach. The housing was designed from the factory for the single double wide idiot light under the tach, and cannot be easily modified for a double idiot light.
The backing was spray painted chrome, and it is not missing any tabs. The shift indicator track is in good condition.
Asking $200 + shipping.
I also have an electronic speedometer that reads in MPH, was in perfectly good working condition in my 86 before I found a KM/H gauge to replace it with.
$50.00 + shipping
$50.00 + shipping
