tach hookup
stumpbuster
farmington, Ct
so i finished changing my ignition module in my carbureted 350, and must have unhooked the tachometer in the process, because i hooked everything back up and i noticed i have a green wire with a spade connector left hangin...:doah:
only thing is, i cant remember where the heck it came out of, and it was a workin tach before i started the job.
there are some connectors on the driver side of the distributer, but there does not seem to be anywhere in that cluster that has room for my tachometer spade connector.
am i missing something?
i should have payed more attention..:whistle:
There is a spot on the HEI cap marked "Tach"...plug it in there. That leads to the negative side of the coil.
ok sweet thanks for the quick and informative response:waytogo:
i will check it 2nite, but as i remember there wasnt any room cuz that was my first guess as to where the wire would ultimately go, could it be "doubled" up with another spade connector to fit into 1 female end by any chance?
