I am putting a tach in the K5, and cant figure out which wire I need to connect into to get the RPM's. I know on a point system that you go to the grounding side of the coil, but I am not a fan of trial and error when it come to clipping wires. I know that its gunna be one of the two wires coming from the dist. module to the coil, but I am not sure, or if there is an easier way to obtain the RPM's from another location I would appreciate the help.
Christian
Christian
