Green Monster
76 K5, putting the gauge cluster back together. Tach never worked right, always read way too high, like 5000 when it was probably only 2500 to 3000. Distributor is HEI, but the back of the tach has a three-prong plug labeled "coil, 12v and ground." Did these come stock with points and a coil? If so, do I need a new tach that will work with HEI? I think the PO Jerry-rigged it with two plugs, one hooked to ground and the other to coil or 12v.
