Cubman
Registered Member
I am wiring my cheap tachometer from O'Reillys in my '78 K10. I need to hook up the white wire to illuminate the tach when the lights are turned on. This wiring diagram says that I should tap into the brown wire from the headlight switch for it to come on with the parking lamps, and the light blue wire for it to come on with the headlights.
http://brochures.slosh.com/wiring/78 Chassis 2.pdf
I took these pictures a minute ago. Do I have the right wires picked out to tap into? Should I have the tach light up with the parking lights or headlights?
