jonathon
Okay since I figure to put plexiglass in the top and make it semi-permanent, at least so it won't fall off when I have the tail gate down.. any suggestions on how to tackle that? I found a couple very old posts regarding the subject but the pictures had long died...
The goal would be to be able to open and close the truck tailgate with the plexi window in the top, and at the same time make sure it won't leak. For some reason I am having a hard time visualizing this part....
Kind of thinking some sort of frame that goes between the top and the body and is attached to the Plexi, with something like the weather strip you find under doors(that stuff seems pretty darn tough considering all the abuse your door goes through daily - yes I'm talking your house door!). The frame itself would only be attached to the plexi and be a friction fit with the top and body.. being able to remove the window with the top partially off the back would be a plus since it is a lot easier to remove the top without the window in place. Since the frame was attached to the plexi, it wouldn't be able to go anywhere when the top is installed on the Blazer..
BTW, driving in western Washington in the winter without a back window is a great way to take a quick, cold shower
Well I'm preparing to disassemble the donor tail gate to get the window, regulator and motor out of it to put in mine that I freshly gutted(which didn't take even 5 minutes to do without the window).
My biggest questions are before putting these in, is there any prep work I should specifically do? Any seals or anything like that I need? My old tail gate had NO seals at all, at least none that were worth saving and I'm not sure of the remaining life of the ones in this new one, and I figure I might as well only take it apart once....
My other question is wiring the tail gate up. I do not want to bother with the key at all. Since I have not tore into it yet, I am curious as to the best way to totally by pass the lock cylinder and put a SPDT momentary on-off-on switch in on the dash so I can roll the window up or down from up front. I figure I'll probably put it on the tail gate to fill the hole but that is the only reason.
Will I have to do anything to latches so I can open the tail gate once the window is down?
ETA: I'm heading off to disassemble it right now, I'll bring the camera and take some pics if I have a specific question....
Another case of WTF was GM thinking when they designed that.. though I suppose the Bronco's are the same thing.. why it can't be easy like a door window I do not know.
