Tail Light harness
dabomb6608
Marion, Illinois
I'm looking for a tail light harness for my 85' K5 Not sure how its supposed to be from factory as my drivers side was cut by PO for a hitch light adapter. My passenger side still has the 4 socket connector and then goes across the back to the drivers side where it meets the drivers side harness that was cut. I will need the 4 socket connector that comes from the taillight itself. Then I guess I need the other side of that connector that comes from the main harness/passenger harness.
Unless it would be easier to remove the whole rear harness if it has a easy to get to connection point further forward in the frame. I haven't looked on mine to see if that's how it works or not.
