Can't speak for the 69-72 K5s.
But on 73-87 pickup trucks, the stop/tail/turn harness connects to the 4-wire, molded harness (that Greg mentions) at the rear of the truck, inside the driver-side frame rail, behind the rear bumper. Its a round connector with about 5 pins (I think). I guess GM did that so you can remove the truck bed easier by just disconnecting the stop/tail/turn harness. So I don't know if that's how its set up on the Blazers or not.
Is there a fuse specifically for the stop/tail/turn lights?
I can't remember... Maybe start simple, and check for a burnt fuse, if you haven't already...
Also, when you use your turn signals, do the fronts still blink? On our trucks, when a bulb is out, the other light lights up solid, but doesn't blink. You can see this on the green-arrow indicators on the dash too. They'll just light up solid, and don't blink. Again, I'm referring to the 73-87s.
Just throwing other ideas out there.
