NEK5
3/4 ton status
I followed my instruction manual (Summit Racing universal harness), the lights are wired correctly...brake switch is wired correctly, and the rest of the wires to the column are correct (according to a diagram from brochures.slosh). I just finished wiring the rear lights, and wanted to check if they worked, so I flipped the turn signal in either direction, and got nothing, hit the brakes, nothing...
none of the lights in front are wired, if that matters...
any ideas? this column was in my 90 blazer, and it worked when it was in there....but its been hanging around my basement ever since (fell off a 6 foot shelf once, I do know that
