Tailgate and windshield
mikeperez22
Can anyone tell me how to pull off the tailgate? I tried everything I could think of. Also, can anyone tell me how to take the windshield out? I need to remove it along with the tailgate before it goes to the bodyshop next week. Thanks.
Tailgate you have to take the hinged support arms off of the bed sides. I just put the hinge so it is going up instead of down. Like an elbow sticking up in the air not down like when you close the gate. You close the gate partially so the shape allows you to pull the arm toward the inside of the bed. Do this to both sides and the tailgate will go down more than parallel to the ground then lift up on one side. I believe the right side comes out first then just lift the gate off.
On the windshield I have never taken one out but I know that you have to replace the windshield gasket so most people take a utility knife and cut the front flap of the gasket off so the windshield can come out.
Hope I explained the tailgate removal OK. /forums/images/graemlins/thinking.gif
That's exactly how I removed my windshield.
Sharp utility knife and cut around the gasket.Then gently remove by pushing from the inside of the truck.
